Rhino 8 section view displays like it's not a closed poly
I’m finding Rhino 8 regularly displays my geometry as if it was not a closed solid when I put clipping planes on. The geometry is always sound and closed. When I backsave and open in Rhino 7 - no issue. Any thoughts?
I’m finding the section views in Rhino8 when using ‘clipping plane’ appear as though they are not solid - but they are. Some display modes don’t do it, but shaded and arctic are often the problem ones. When I open the same models in Rhino7 they appear solid, as they should. Anyone else seeing this issue?
Thanks,
Hi Jonas -
Please post a 3dm file and the output of the Rhino SystemInfo command when you run into something like this.
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Educational, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.7
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 8-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 561.03
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-30-2024
Driver Version: 32.0.15.6103
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
Here is a grab of the issue and the 3DM file.
Thanks for your help.
Closed bottle.3dm (19.7 MB)
Did you have a chance to look at this~?
Something is odd about the geometry, note that you are working with in a millimeters file with .000001 tolerance.
I exploded the polysurface and changed the document tolerance to .01 mm, then ran the Rebuild Edges command on the surfaces and rejoined at the .01mm tolerance.
I have it in other files with smaller tolerance (0.001) and sometimes it even displays half solid and half open on the same closed component!
See image:
Looks like there are geometry problems or oddities.
If you run selectbadobjects everything if fine, and if you run showedges it looks clean, until you turn on all edges,Take a close look at the blend around the setback to the top opening, there seems to be overlapping surfaces, this will cause confusion as to object surface normals.
I’m a little surprised this passes a selectbadobjects command, a fail would have helped identify the problem in order to correct them, If this is for manufacturing I could see the issues continuing.
