Rhino 8 Script: Editor keeps loses caret
When using script editor in R8, sometimes the caret (text cursor) will disappear after each key stroke, and I’d have to click again to input the next charater. I think it mostly happens after moving code around using alt+arrow key.
Animation2
Side note, sometimes if I save the script, then press run, but rhino crashes, the next time I open script editor, it doesn’t open the saved version, but the verion of script before the save.
Hello @victorlin
Which version of Rhino are you using? I have made some improvements on this for 8.5 RC
I am also working on getting the save/reopen glitch resolved
RH-79718 ScriptEditor: Reopen glitch
I’m on the latest service release, 8.3.24009.15001, 2024-01-09
@victorlin Ok one more test. Would you mind checking when this happens if the “Problem” panels at the bottom of the editor is open or not? When you change the script, the problems panel updates with new diagnostics info and may be stealing the focus.
Also I would appreciate if you can test this in 8.4 Release Candidate
This is a issue that I’m unable to recreate on demand, sometimes it keeps happening, others times it works fine. I’m currently unable to recreate.
I don’t think I use the problem panel at the bottom, terminal is chosen, but find panel on the left is expanded.
Will test more and report back if it happens again.
Thank you @victorlin
it’s still happening on 8.4, it’s not as bad as beofre, there’s a slight delay, if i continuosly type, it’s fine, but if i pause it loses the caret.
it is as you said, the problem panel is stealing the focus.
Animation
it seems that if I use ctrl+up arrow after it loses the caret, it temporary “fixes” the issue for a while
So this issue had came up before and we put a fix in Rhino. I can not replicate this in 8.5 or local builds. I can replicate it in 8.4. Would you be able to test in in Rhino 8.5 release candidate?
hate to break it to you, but i’m still experiencing it on 8.5
Animation2
Uh not good. Okay I’ll dig into it today. This should not happen.
So one of my observation (might be wrong), is that I have a habbit of double clicking the error in the problems panel to highlight the line, is seems to happen after double clicking
Also happens after usign search, double clicking the search results will result in the search pane stealing focus
Okay good clue. I was able to replicate this in 8.5 and pushed a fix. I can send you a new installer to test tomorrow if you want. Otherwise another 8.5 is released on Tuesday
Even better, in all likelihood 8.5 will be released as the actual service release on Tuesday.
I’m having the same issue. I’m on 8.15.25019.13001 which I believe is the latest. I am typing and then its picking up errors in the problems console which is a great feature. I believe that is what is causing the caret to get lost. Every time it picks up a new problem it changes the focus from the editor. Unfortunately as I’m typing there are constantly errors, since the work is incomplete. I need to type with one hand and then use the mouse in the other to keep clicking in.
Can we prioritize this as a fix since it renders the new editor unusable?
I put a fix for this in 8.17. @Benjamin_Paolo_Fortu I can send you a test build if you want
Thanks! I’ll wait till 8.17 comes out. I don’t want to bring up any other issues. I’m moving the project to visual studio to create a grasshopper plugin anyway since the project has grown in scope so I won’t need the editor as much.
FYI I also had some issues tying to install a NewtonSoft,json package. You can see the post here How to manage assemblies in new C# editor? - #17 by Benjamin_Paolo_Fortu.
I might be doing something wrong or there is something in the debugger / package installer that is not working. I’m moving to a plugin so I gave up on trying to solve this, but if it is a bug it might be something to take a look at in the 8.17 release.
