Rhino 8 Script Editor Author field supporting non-ASCII characters?
Hi @eirannejad,
I just finished converting my plugin from the old ScriptCompiler to the Script Editor (replacing old .rvb scripts with .py verisons) and I noticed that the plug-in failed to publish when I had non-english characters in the author field. Characters like æ and ø worked fine in the old scriptcompiler:
In the script eidtor, I received the below error and was unable to publish until I replaced the characters
Not a major issue - just wanted to make you aware
Oh interesting. That is definitely odd and a bug. I filed here and will get it fixed. Thank you for reporting! :pray:
RH-85806 Project author does not accept æ or ø
@Michael_H On the first try I can not make this error replicate. Would you mind DMing me an example?
How strange - I also can not replicate it if I create a new project, I only have an issue when I import the old .RHC project into script editor. I will dm you the .rhc file if it’s helpful, or maybe it’s just a me issue :slight_smile:
RH-85806 is fixed in Rhino 8 Service Release 17
