Rhino 8.14 German: command SkriptEditor isn't starting the first time
Hi…,
when I start Rhino 8.14 German, and type “SkriptEditor”, Rhino doesn’t know this command sometimes.
After starting _ScriptEditor, closing the ScriptEditor-Window, typing the German “SkriptEditor” command, it works.
Also the German doc is defect:
https://docs.mcneel.com/rhino/8/help/de-de/index.htm#commands/scripteditor.htm
SystemInfo.txt (2.3 KB)
Thanks
Michael
FYI: This seams to happen after the installation of a new Service Release.
This is an old problem, also existed in V7 IIRC, and was the same with PythonSkriptAusführen (RunPythonScript).
Hi @wim,
still happening after installing the latest SR.
Is this something for your bug-tracker?
Thanks
Michael
Hi Michael -
In a quick test here, that seems to be fine.
What are the steps needed to reproduce this issue?
Hi Wim,
install the latest SR, German UI, and type the German command “SkriptEditor”.
Thanks
Michael
Exactly. I can’t remember if this happens only just after having installed a new SR, or if it happens every time Rhino or the computer is restarted.
BTW, happens also in French.
