Hello, all!
I’ve been using Rhino for laser cutting since Rhino 5, but it looks like the changes made to printing in Rhino 8 might have had an unexpected effect on our laser cutting workflow.
For reference, I’ll be using Epilog Fusion M2 lasers here since that’s what we have in our makerspace. I can print to these lasers from other programs like Illustrator, and I could print to them from Rhino 7 and everything works fine. This is an issue for the Epilog lasers I’m using here because our lasers require all of your settings to be done in the print preferences, and not on the machine or another program, just like a normal paper printer. I could send these files to our Trotec lasers and they’d be fine because even if the settings are discarded, I can set them again in an intermediary program.
When I go to print, all of the settings in the main print menu work
Next, I select the print Properties to set my Vector settings, which I would expect to apply to the rectangle curve on the outside, and settings for my Raster settings, which I would expect to apply to the hatch in the center.
However, when I check and see what settings have actually been sent, all of my values have been reset to the default of 50. I could change other settings like engrave direction and they’ll be reset to whatever the default values are before they’re sent to the laser.
I’m speculating that Rhino 8’s discarding any settings set in the printer preferences instead of passing them on to the printer.
This could potentially be replicated without a laser cutter by installing the Epilog laser drivers and Epilog Job Manager, which is an intermediary program that you can send print jobs to and then send those jobs on to Epilog laser cutters, which are located here Fusion Driver and Firmware Updates, and then viewing the settings that were passed on to Job Manager. My sample file is the same as above.
laser settings test.3dm (43.7 KB)
Thanks for any insight y’all can provide! Luckily for us, this isn’t too impactful for our usual workflow, but it did derail some of our Rhino workshops.
_SystemInfo.txt (2.4 KB)
