Not just teachers, but also technical support, instructional videos, documentation and the like. Not to mention common code base for the developers.
Time will tell if this happens and there is a “mass exit” of Mac Rhino users as you seem to predict - or if people will just get used to using the software in a slightly different way than before and get on with their business.
Dunno, if I type dim and Enter in V7/Mac or PC I get the command Dim(ension) that launches - Dim is actually the full command name. Exactly the same on V8/Mac or PC. I only have V5 for PC running, but it does the same thing.
Commands have not changed significantly between versions, so I don’t know what you are describing here. Everything is still in the menus. If there are differences in how the Autocomplete fuzzy logic works between V7 and V8, then it’s probably on both platforms, not just limited to Mac Rhino.
Yes. As a matter of fact, for future versions, it’s probably going to continue in the direction of more unification, not less. Who knows, maybe V9 for Mac will finally get a real command line…
Just for fun, here is a page from the Blender forum, who apparently changed the interface recently.
(Don’t know personally, I am not a Blender user. Are the Mac/PC interfaces different in Blender?)
The comments seem very similar to here…
