Rhino 8 Keeps Crashing When I Attempt To Open It
This is what it says.
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for ‘CrossGemsGH.Display.DrawServer’ threw an exception. —> System.NullReferenceException: Object reference not set to an instance of an object.
at CrossGemsGH.Libraries.Materials._x1MBBEwUln546OvNGIFBlCK22jH(String )
at CrossGemsGH.Libraries.Materials.GetMaterial(PlasticType material)
at CrossGemsGH.Display.DrawServer…cctor()
— End of inner exception stack trace —
at CrossGemsGH.Display.DrawServer.AddPost(DrawObj drawObj)
at _5e._kgc(Object , RoutedEventArgs )
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
[END ERROR]
Sorry to hear that @sikim,
It sounds like a 3rd party plugin (CrossGems) is causing the issue, can you try running Rhino 8 in safe mode, it should load without plugins, and if that’s the case, it narrows down the issue.
how would I run rhino 8 in safe mode?
You should be able search “Rhino 8 in Safe Mode” in your windows search and it should be available to you.
Failing that, It can be found here
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Rhino 8.
And failing that you could run this from powershell or cmd & "C:\Program Files\Rhino 8\System\Rhino.exe" /safemode
Ok so I figured out that CrossGems is causing the problem. I use crossgems all the time and this is the first time that it is causing me any problem. What should I do? Should I uninstall crossgems and try installing it back?
I would try uninstalling and reinstalling it, and ideally trying the latest version of it.
What version of Rhino are you using, and does their software recommend a specific Rhino Version?
I am using Rhino 8 at the moment, when I load up Rhino, it says that there is an update available these past few days and I have always closed it out. The software crossgems is built specifically for rhino 8
if you’re not on Rhino 8.7 I’d upgrade to that as well as upgrade CrossGems, if that still doesn’t work, we can try some other things next :slight_smile:
How would I upgrade Rhino 8? I try to upgrade rhino 8 when I open it, but it crashes before I could do anything.
I think a fresh install may be in order for Rhino then. Why don’t you uninstall it, then reinstall it fresh from this link
https://www.rhino3d.com/download/rhino-for-windows/8/latest/
If you have many custom toolbars and settings it might be worth backing those up first
i uninstalled crossgems and reinstalled it, it fixed the problem. Thank you!
Glad you have a working setup again :slight_smile:
