My rhino6 crash and cannot work while opening up
It’s a rhino 6 evaluation, and I tried to re-download it for many times and it just went the same.
And here’s the log
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for ‘System.Windows.Automation.Peers.AutomationPeer’ threw an exception. —> System.BadImageFormatException: Could not load file or assembly ‘UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The module was expected to contain an assembly manifest.
at System.Windows.Automation.Peers.AutomationPeer.Initialize()
at System.Windows.Automation.Peers.AutomationPeer…cctor()
— End of inner exception stack trace —
at System.Windows.Automation.Peers.AutomationPeer.RaiseFocusChangedEventHelper(IInputElement newFocus)
at System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp)
at System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
at System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
at System.Windows.Input.KeyboardDevice.Focus(IInputElement element)
at System.Windows.UIElement.Focus()
at System.Windows.Input.KeyboardNavigation.Navigate(DependencyObject currentElement, TraversalRequest request, ModifierKeys modifierKeys, DependencyObject firstElement, Boolean fromProcessInputTabKey)
at System.Windows.FrameworkElement.MoveFocus(TraversalRequest request)
at Eto.Wpf.Forms.WpfWindow`3.b__25_0(Object , RoutedEventArgs ) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\WpfWindow.cs:line 95
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
[END ERROR]
Anyone can help me??
Hello - did you send the crash report? What version of Windows are you running? Is Windows completely up to date?
