Volume calc example.3dm (1.5 MB)
Hi, this is an example. When I use the shrink-wrap command, it calculates the volume from the outside in.
However, if instead of wrapping the shapes from the outside, the wrapping algorithm started from the inside, that would save us a lot of time. I hope it is clear.
There are many workarounds that we use to measure the volume, but using shrink-wrap would be such a convenient and fast method.
EDIT: in the example attached, I’d like to measure the volume inside the curvy shape, excluding the volume of the spheres and boxes.
