Rhino 8 - Extract Clipping Plane Sections should extract Hatches
Would be very uselful to have the Hatches also - Since they could be already created by the Clipping Sections.
Please!
hi @Bogdan_Chipara you need to check it in the commandline options, it’s off by default:
ok, but here’s what’s a bit confusing.
If you have the Clipping Plane selected, and you run _ExtractClippingSections the commandline options don’t show up.
there are many commands in Rhino that don’t show options with preselected geometry. The option is sticky, so once you have run it with hatches on, you can preselect the next time you run. Does that suffice?
For me yes, but I always think from the point of view of a user which is less experienced and less interested in learning all the capabilities of the software.
And this is a new feature and quite a good one. I would push it to be more user-friendly.
