Rhino 8 dual monitor/panel
Hi Everyone.
I have an issue with Rhino 8. I used to have several monitors in rhino 7 utilizing floating panels. However, I can’t seem to use my dual monitor setup with rhino 8. When moving the panels to the other monitor they disappear - is it a bug or am I doing something wrong?
like this:
Window > Panels > Material move that panel to the other desktop om my monitor
I use an M1 Max
Thanks!
This has been solved with one of the recent updates. Try updating to the latest release.
Hi John! it seems im running the latest version 8 (8.2.23346.13002, 2023-12-12) already. however its the trial version, but I don’t think that should matter.
same problem. In dual screen setup the foating toolbars disappear. Rhino updated and nvidia RTX5000 driver already udated. It seems no one care about the problem. I bought Rhino 8 for professional job. We use it in parallel with SW and we never had UI problems.
Hi Cesare -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR4 2024-1-23 (Rhino 8, 8.4.24023.15001, Git hash:master @ e0f90d20c78f2125a0ec9cfffc9d9decbc052c01)
License type: Commerciale, build 2024-01-23
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 5000 (NVidia) Memory: 15GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 15 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot12RhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.1.0.0\KeyShot2023RhinoPlugin\Rhino 7\KeyShot2023RhinoPlugin.rhp “KeyShot12RhinoPlugin” 1.0.0.0
C:\Program Files\Scan&Solve Pro for Rhino 6\SnSPro_Rhino6.rhp “Scan&Solve Pro for Rhino” 1.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Rhino 3DM File Version (aa091cb2-d8c0-4944-a17d-b66c80bec4ca)\7.0.7639.20582\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.7639.20582
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24023.15001
Hi. Today 13 march 24 finally the issue with toolbars in dual screen setup is disappeared. I don’t know if the solution is due to the Rhino 8 update or the Windows 11 update. Both started today morning so it’s impossible address wich ever was the solutor. In anyway I’m so happy to start using Rhino 8 at full potential.
Something that would be a meaningful improvement for multi-monitor workflows would be if panels could be docked and arranged in a second window, rather than just floating all the panels individually and having to manually align them and try not to click on things behind/around them.
Is this possible/am I missing it, or would it be a reasonable ask for something to add?
Currently I end up ‘clicking through’ to underlying stuff sometimes by accident on my 2nd monitor, and of course as soon as you do that, all your rhino-related stuff disappears.
