Rhino Crashing when Opening
Rhino 8 consistently crashes when opening on Mac. I have tried reinstalling and changing Rhino Render to CPU, but neither has solved the issue.
Sending crash reports with email address too.
Don’t suppose anyone has any trouble shooting ideas?
You might try the Reset tool:
Any luck?
Hi Will -
Which version of Rhino are you trying to use?
Have you had Enscape installed on your system at any point?
I am currently using 8.18.25100.11002
I have not had enscape installed, no.
Many thanks,
Will
Thanks, Will.
Could you provide specifics about your machine? Both the macOS version and hardware that you are using.
Hi
Yes, i am using MacOS 15.4.1 (24E263) on a 13-inch, 2020, Two Thunderbolt 3 port Macbook Pro - 1.4 GHz Quad-Core Intel Core i5
Thanks,
Will
Just wondering if you’ve had the time to look into this any further?
Many thanks,
Will
Hi Will -
Sorry, things keep falling between the cracks here… Thanks for the reminder.
I’ve taken a look into our records and I can’t seem to find any crash reports from the email address that you’ve used to create your profile here on Discourse. Are you using a different email address when sending in those reports?
Sorry - yes it’s assigned to my university email. 10046330@network.RCA.ac.uk
