Ansen.A
1
Hi,ALL
When I use the BooleanSplit command to split a surface, the result is an open surface, which is normal in Rhino 7.
I need to extend the cutting surface in order to obtain the correct result.
The following is the attachment:
BooleanSplit V8.3dm (168.3 KB)
Yeah, I see that. It happens even with a new file, a new box and a simple plane the same size as the box. Something got broken…
wim
(Wim Dekeyser)
3
Thanks!
I’ve put this on the list as RH-79376 BooleanSplit: Creates open objects
