Rhino 7 WIP - Revit addin: translation into wall / ceiling / window?
It’s exciting to see Rhino integrated into Revit as I was having hard time modeling complex and organic geometries in Revit. I couldn’t find a lot of tutorial materials as to how to actually use both in tandem.
For example, how would you export an box object from Rhino as floor, ceiling, or window component in Revit?
If you are new to Grasshopper and Rhino & are an Architect who does complex and organic geometries perhaps you should try Conveyor – which simplifies the process a bit, at a cost.
See this
https://www.rhino3d.com/inside/revit/beta/samples/transfer-rhino-to-revit
