Hey Wim,
Thank you for your answer. The Make2D command works fine, it seems that the problem happens when I want to export the drawing as a PDF file. Suddenly some of the lines disappear which in the version 6 was not happening.
I usually build the design in 3D, choose the right view and with “Make2D” command change the design to lines and prepare the drawings for 2D export out of Rhino. In that step I use “export selected”, select “save as type:PDF” and choose the window I want to export. Type of PDF export - vector graphic. I have been using this for a while and it always worked perfect.
Thank you very much.
-Jan
220116_Lab.3dm (6.2 MB)
This is the “SystemInfo” result:
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Educational, build 2022-01-10
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 8-25-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.84
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-25-2019
Driver Version: 26.21.14.3184
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\export_PDF.rhp “PDF Export” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22010.17001
