Hello, I wanted to open my Rhino 7 (Windows 10) after over a year and Rhino just didn´t open. Nothing happened after I clicked on the rhino icon, not even after reinstalling the program. Any idea what´s happened?
Thanks
Thanks
After a machine sits for a year this is usually pending Windows updates or an out of date display driver.
Lets try these:
If it still won’t open, check Windows Event Viewer > Windows Logs > Application for an error at the time you launch and post it here.
Also try starting Rhino in safe mode — type “Rhinoceros 7 in safe mode” in the Windows start menu search. If it opens that way, run systeminfo in the rhino command line and post the results. Thanks!
Did your computer sit unused for a year, or did you simply not open Rhino for a year?
most likely a .net repair will be required.
