Hi, So I’ve been looking around this forums trying to figure out why my Rhino isn’t working and have tried everything posted. But it still doesn’t launch. I can see in my Task manager that the application has launched, but the app doesn’t pop up.
But apparently they gave me this Notepad to look at (but I’ve converted into a PDF to be able to upload), and I’m not sure what it means.
Yes, I’ve tried rebooting my PC and my Windows is up-to-date and it still didnt work, However I am currently using a ASUS Rog Strix. By they Im referring to the Rhino 7 app itself, because I left the app running in the background (without force quitting it, even though the app didnt launch) for a few hours and it gave me that notepad file.
Hi - have you ever been able to run Rhino 7 on that machine or is it the first time that you are trying? Have you tried repairing the installation in the Windows control panel?
In Rhino 6, please run the SystemInfo command and copy-paste the result here.
So, Ive tried opening Rhino for a second time and I noticed that it doesnt work. But when I open it in safe mode, it opens. Here is my SystemInfo. How do you think I should proceed?
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 31Gb)
Primary display and OpenGL: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 1-7-2021 (M-D-Y). OpenGL Ver: (null)
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-10-2021 (M-D-Y).
- This device is not being used
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 1-7-2021
Driver Version: 27.20.14016.7001
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
Total Video Memory: 512 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.4.21078.1001
Swap your monitors.
Make the laptop screen primary and the external secondary
Additionally, ASUS installs a utility that causes trouble with 2nd monitors.
To test, see if Rhino comes up on the built in monitor and runs correctly with no second monitor.
You might try a clean install of the gpu drivers - not sure what the above ‘n/a’ ‘null’ really means but somehow does not look all that promising for Rhino.
