Rhino 7 Layout Panel
Please, would be possible to add possibility to create “groups” of layouts similar to layer and sub-layers logic. It would help significantly to organise large architectural projects for example plans, sections, views, details etc. Same for exporting, to have possibility to “tick” only drawings/groups to print to pdf.
Thanks a lot!
Tomas
Hi, check this Wish - Layout groups
Hi Tomas -
This feature request is on the list as item RH-29946.
This one is here: RH-55300.
I’ve added your vote to both.
Thanks,
Thanks a lot!
Please also ad the option to export / print (PDF) to individual pdf sheets from a layout containing many layouts.
Adding a “Pdf print with file name” pane in the layout panel would enable us to name in the layout panel the exported pdf and thereby print many individual pdf sheets with the specific drawing number/name already on them.
Hope this makes sense (the architects will know :slight_smile:
Please make this happen :slight_smile:
@wim Please, It’s been five years since this was last discussed — is there any chance this could make it into Rhino 9 WIP?
This would be very welcome. We sometimes have so many layouts could be more than 50-100. We missing this feature a lot !
Hi Tomas and Sven -
Dale has recently started looking into applying “groups” to other things than geometry and first off is using this on layouts.
→ RH-49935 Layout organization tools
While that item is set to 9.0, we’re basically not adding more stuff to Rhino 9 than what can currently be found in the WIP at this point in time. This one will require more under the hood development and UI changes on top of that, so it remains to be seen where this ends up.
RH-49935 is fixed in Rhino WIP
