Rhino 7 - Hatch option inactive?
Hi!
I have never encountered this, hopefully it’s an user-error from my part. I have tried to look on the internet for a solution but I haven’t found a solution to my problem.
When I make a hatch in the document, the properties seems to be “locked”, and I can’t change the values. Why is this?
Best,
Li
Hi Li - does that happen with any hatch, or just some? Can you post an example?
Oh, if the hatch is solid, rotation and repeat do not apply
Hi Pascal,
Thanks for the reply.
I have tried the other hatches and it looks like it’s only Hatch 1 that is diabled, why is that?
The only reason I have been able to fill in the parameters with rotation and scale was to copy a hatch from another document, and then using the “Match” function …
Please see another screenshoot.
Hello - can you save off that hatch and post the file here?
Sure, here you go!
Thanks for having a look.
20210528_Hatch.3dm (1.8 MB)
Hi @x2design thank you for the file. This is definitely a bug. I’ll have a look and get it fixed up.
https://mcneel.myjetbrains.com/youtrack/issue/RH-64423
Thank you!
Best,
Li
