Good Evening. I have a lot of delays in an object mainly when I work in rendered viewport
Hi Πέτρος Ανδριανός,
Please type SystemInfo into the command line and paste the results here. Thanks
Rhino 7 SR31 2023-6-15 (Rhino 7, 7.31.23166.15001, Git hash:master @ 850d276b2d59d7e51843939e4cf674b356bcd354)
License type: Evaluation, build 2023-06-15
License details: Cloud Zoo
Expires on: 2023-08-23
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 6-10-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.25
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2023
Driver Version: 31.0.15.3625
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.31.23166.15001
there is a difference for the better. However, the result is not optimal for an object without many details and with a 12-core processor and a graphics card asus rtx a4000
Is this a particular file or any object in a rendered view? Is the object extremely far from the 0,0?
If you can post or send the file that is troublesome we can take a look.
https://www.rhino3d.com/upload
Thanks
do you have a ton of blocks in the scene? Are they structured poorly with blocks inside of blocks inside of blocks?
If so, run the selblock command, then explode blocks = all
does that help?
poorly structured blocks are notorious for causing unexplained slowdowns… explode them, and re block them at one layer deep and they will run way faster.
Do you recommend that my objects be in the form of surfaces rather than solids? I understood correctly?
A “block” in Rhino is a way to organize and use objects. Using Blocks [McNeel Wiki]
A “solid” in Rhino is a closed surface or polysurface.
no, see here-
