I would like to confirm the compatibility of Rhino 7 with the following Mac configuration.
Machine specifications:
MacBook Pro 14" M1 Pro 16/512gb • M1 PRO con CPU 8-core e GPU 14-core
• 16 gb ram
• 512 gb ssd
Could you please confirm if Rhino 7 runs correctly on this machine and if there are any known limitations or performance considerations when using Rhino on Apple Silicon processors?
It should also be noted that Rhino 7 for Mac uses OpenGL while Rhino 8 for Mac uses Metal to display geometry. We made the change because we were running into OpenGL issues on Mac and Apple has officially marked OpenGL as a technology they will not be supporting in the future.
