Rhino 7 & 8: Get Updated STEP Import/Export Settings in session via API
Hi @dale @Gijs
I’m developing a Rhino plug-in and I’m facing an issue with the STEP Import/Export settings in both Rhino 7 and Rhino 8.
When a user opens the STEP Import/Export options and changes the settings, I’m unable to retrieve the updated values through PersistentSettings. The PersistentSettings object appears to return the previous/old values instead of the values that the user just changed in the UI.
Is there a supported way in the Rhino 7/8 API to retrieve the latest/updated STEP Import and Export settings after the user changes them?
Any API, event, command, or recommended approach to access the updated settings would be greatly appreciated.
Thanks!
hi @Ram_D these settings get saved only when the user shuts down Rhino.
Hi @Ram_D,
Also, Rhino only stores non-default values in persistent settings.
– Dale
Thank for reply @dale @Gijs
I noticed the following behavior:
Open Tools → Options.
Click OK.
The updated value is immediately reflected in the settings-Scheme__Default.xml file without shutdown rhino.
However, in this case I get the updated value in PersistentSetttings and settings-Scheme__Default.xml.
This made me wonder:
Is there any other file, cache, or internal storage where Rhino temporarily holds the changed Options values before they are committed to settings-Scheme__Default.xml?
If so, is there a RhinoCommon API to access those updated values directly, or an API to force Rhino to commit/save them immediately, similar to clicking Tools → Options → OK?
Hi @Ram_D,
Have a look here:
– Dale
