I’m looking for some guidance on using the PersistentSettings class from a Rhino 6 plugin.
I see the API documentation, but it’s not clear to me how to set this object up with defaults and initiate loading and saving. Like, where do I fill in the initial setting keys and values for the very first run, which will then be changed, saved, and loaded in future runs?
At first I was trying to use the regular old WinForms .NET Properties.Settings.Default class… but soon found that it is not working/supported from the plugin, and that Rhino.PlugIns.PlugIn contains a PersistentSettings class of its own. I’d like to use it
Well… It looks like it was as simple as checking if the settings were there, and if not adding them programmatically, then updating them, and next time plugin loaded they were there. I guess everything is handled behind the scenes. Worked like a charm, easy peasy
I’ll leave this open in case there are any other tips anyone wants to add.
How to wipe any PersistentSettings that I added?
Or where are they stored?
I tried using Settings.DeleteItem() to remove them from memory, hoping it would remove them from the saved settings file… but when I reloaded the plugin it was able to find the previously stored keys and their values. I’d like to clear out anything I added and start fresh.
DeleteItem() is correct, you just need to remember to also SaveSettings() once you’re done.
I have a command for RhinoCycles to clear out all settings. I do that as follows:
FWIW, what I do for RhinoCycles is to have always hard-coded defaults that I use as the default value for getting. I have also implemented the reset button for the options page (OnDefaults
You should almost never have to call DeleteItem. Always try to provide a default value when getting a setting. When the setting is set to its default value it will not be saved to disk.
The test command I wrote for the case where a setting is no longer used, but still may be in a settings file. These will linger unless you actively delete them. Other than that indeed default values it is.
