Hi!
I would need Rhino 6 to use it in combination with Eddy 3d, which is not working with Rhino7.
As this issue should be fixed soon I was wondering if a trial version of rhino 6 is still available?
Thank you!
Best Pia
Hi!
Thank you!
Best Pia
Hi Pia -
No, that is no longer available. Evaluation versions are only offered for the current version of Rhino, in this case, Rhino 7.
For what it’s worth, when a Rhino 7 license is purchased, a license key for Rhino 6 can be downloaded.
Thank you!
Is it possible to have both versions installed with the same license?
No, a license is for a specific version - a V7 license will not run V6. But, as Wim said, buying a full license of V7 gives you the right to get a free V6 license as well. Rhino - Access Rhino 6
Perfect. Thanks for the link!
unfortunately, I still can’t use the license. In the licensing Popup I received this error message:
Do you have a solution for this?
Thank you!
I looked at your licenses and I see a purchased V7, and a V6 “downgrade” bo added to your account.
You should be able to run either V7 or V6 now.
Hi John!
I still receive the same message. I’m not running another Rhino7 file simultaneously and I’m connected to the Internet. What else could be the problem?
Yes it is.
I don’t have to deinstall rhino7 if I want to use rhino6, right?
No.
You own a single computer license that will run V6 or V7 on different computers.
If you have enough system resources, you can run V6 AND V7 on the same computer at the same time.
