Rhino 6 Service Release Available
Rhino 6 SR31 (6.31.20315) is now available for Windows and Mac.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
Bugs Fixed:
  • Display:
    • Extrusion display does not update when isocurve density changes (RH-53724)
    • Extrusion display does not update when wire density changes in object properties (RH-60820)
  • File IO: DWG Import - Should not change annotation scaling in DocumentProperties (RH-60640)
  • Print: Trimmed PictureFrames gets the images wrong (RH-59787)
  • SDK: Python: rs.AddAlignedDimension fails when points passed are colinear (RH-61121)
  • UnrollSrf: Misbehaving unpredictably (RH-60119)
Mac-Only Changes
Bugs Fixed:
  • Panels: Block inspector panel goes wacky on a file (RH-60754)
Windows-Only Changes
Bugs Fixed:
  • Installer: Rhino fails to start (RH-61310)
Performance Improvements:
  • Annotation: Spell check in edit box is turned off to avoid lags (RH-60691)
Rhino 6 SR32 (6.32.20340) is now available for Windows and Mac.
Bugs Fixed:
  • Display: Rhino crashes when external monitor is configured as the "Main Display" in Windows. (RH-61606)
  • File IO: SKP Import - Transparency incorrect (RH-61756)
  • Licensing and Validation: Standalone NFR validation yields unexpected behavior (RH-61571)
  • SystemInfo: Added more details about attached monitors and GPUs (RH-61763)
Crashes Fixed:
  • Rendering: Cycles: OpenCL for CPU driver causes crash (RH-61768)
Bugs Fixed:
  • Build Process: SCCM cannot detect Rhino - FileVersion field incorrect (RH-61809)
Rhino 6 SR33 (6.33.20343) is now available for Windows and Mac.
Bugs Fixed:
  • Menu: Links to Discourse fail (RH-62295)
  • SDK: RhinoCommon: EtoCollapsibleSectionHolder turning off scroll bars makes section disappear (RH-61988)
Crashes Fixed:
  • SDK: CRhinoObject constructor is not thread safe and that causes some VIsualARQ crashes. (RH-62564)
Rhino 6 SR35 (6.35.21222) is now available for Windows and Mac.
Features:
  • A rework of the licensing flow to simplify moving of licenses between computers and Rhino Accounts, especially when Rhino 6 licenses are upgraded to Rhino 7.
