Rhino 6 SR29 Release Candidate 1 for Windows and Mac (6.29.20210) is now available
Bugs Fixed:
- ArrayCrv: Issue when not picking a base point (RH-59472)
- Display: SR27 has broken certain configurations that use/require lower levels of OpenGL… (RH-59448)
- Rendering: Post Effects hang up (RH-59485)
- SDK: Python: SDK Python: rs.OffsetCurveOnSurface() doesn’t work the same as Rhino.OffsetCurveOnSurface() (RH-59447)
- SDK: RhinoCommon: SDK RhinoCommon: Remove Mesh.IsPointInside from Rhino3dm builds (RH-59355)
Regressions Fixed:
- Eto: Window.Icon property raises “handle is invalid” exception in Rhino 6 SR26 (RH-58972)
Mac-Only Changes
Bugs Fixed:
- Display: Curve Display Error (RH-58768)
- Grasshopper:
- Grasshopper: Components: Grasshopper: Components: C#/VB Grasshopper component crashes Rhino when trying to change the font (RH-59434)
- Layout: Size doesn't stick causing several issues (RH-58911)
- Panels: Icons get clipped (RH-59421)
Crashes Fixed:
- ObjCRuntime.RuntimeException: Failed to marshal the Objective-C object 0x7fd033e86fe0 (type: Eto_Mac_Forms_Controls_ScrollableHandler_EtoDocumentView). Could not find an existing managed instance for this object, nor was it possible to create a new managed instance (because the type 'Eto.Mac.Forms.Controls.ScrollableHandler+EtoDocumentView' does not have a constructor that takes one IntPtr argument). (RH-55546)
- Display: Polyline: com.mcneel.rhinoceros.RhCore:std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >::basic_string<std::nullptr_t>(char const*) (RH-59316)
- Eto:
- Grasshopper: System.ArgumentNullException: Value cannot be null. (RH-59499)
Windows-Only Changes
Bugs Fixed:
- Panels: Can't drag materials in panel (RH-59418)
- Toolbar: Saving RUI file to a DropBox folder fails when renaming temp file (RH-59467)
Enhancements:
- Help: Add a note about the "Run GHS" functionality (RH-59199)
