Rhino 6 - Match Properties Error
(upload://burOxG6RUy5hTZOXtOU1Fu5vuHW.png) ![image2|690x443]
When trying to apply the source object (googlemaps) onto my surface (topography) the source object seams to flip and therefore not perfectly being mapped onto the surface (topography).
When applying it to a completely flat surface, it projects perfectly.
Anyone has any suggestions / other options to try?
Thanks!
Hello - make sure the target objects’ U and V match what you expect them to be (presumably the flat surface) Use the Dir command to set directions.
Thanks a lot :slight_smile:
  • Jaime
