Rhino 6 - Can't change materials
Hi, I hope my question will be silly and fast fixing, since today I can’t change materials on my models.
I used to generate a layer with a proper material, and then creating same material’s object in the same layer but now it’s not working.
I still can change color layer but not material, material column looks freezed
(not running any command)
Thanks for you time
Hello- please run the SystemInfo command in Rhino and copy/paste the results here.
Are you trying to change a material in a Block?
The Computer are pretty new and strong, if this was the point, or tell me which line you need?
Thank you for answering
No, I’m not.
Should be a setting issue
Hi -
Nothing less than the entire outcome of that command.
Hello - if you click on the (faint) white dots here
nothing happens, is that what you are reporting?
Yeah, when double cliking on there I can’t change the material,
The other columns, like type or color, are editable as always but not the materials one.
Hi -
In the PluginManager, please check that the Renderer Development Kit UI plug-in is both Loaded and Enabled.
thenkyou for answering, the renderer development kit ui isnt enabled and loaded, infact down in the same window I have the install (installa) botton, should I have somwhere the install file? or should I install from zero Rhino?
After just enabling it the materials are still unchangable, so the problem isn’t fixed.
How’s possible it has been unistalled by itself?
Hi -
Just enabling will not suffice. You also need to load that plug-in. Right-click on the plug-in name and pick “Load”.
Alternatively, you could try to “Repair” the installation from the Windows Control Panel.
If you keep having problems with this, I would see what happens when the Lumion plug-in is disabled.
The load process has been done automatically after restart, the problem look like it’s fixed, many thanks.
Right now
has appeared this 2 window asking to load plug-in now, but doesn’t generate any issue.
01
02
One more question with “system info” may I ask you what have you checked?
Hi -
I would try a repair of that installation.
Everything.
So I should download the setup file from mcneel.com and run the setup with the repair option, understood.
Once again many thanks for you time and kindness
Hi -
No. You don’t need to download anything. Just go to the Windows Control Panels → Programs and Features. Find Rhino 6, right-click and pick “Change”. Then pick “Repair”.
the repair procedure didn’t worked as expected, still have those problems when starting the program
