Material handling bug in V5
If you make a new object in Rhino, then changes Assign Materail By: Layer to Object and do nothing else and then open the material editor then there are no materials there. So the new material created is still not existing in a way. I have to make some sort of change for it in the object properties first for it to appear in the Material Editor.
Hi Jorgen - got that - thanks.
OK, I see that it works as you ask in V6.
Thanks for checking. I can’t use V6 on this computer since environment light calculations turns objects black.
