Hi - As far as I can tell, this thread contains several possible issues.
Please run the Rhino SystemInfo
command and post the result here.
Thanks!
Her is my Info on the system:
Rhino 6 SR11 2018-12-10 (Rhino 6, 6.11.18344.20091, Git hash:master @ d3871e1724fc30d4dcb18cd1911c7ad439d0c93d)
Licence type: Kommerziell, build 2018-12-10
License details: Cloud Zoo. In use by: Alexander Hesse ()
Windows 7 SP1 (Physical RAM: 4Gb)
Machine name: USER
ATI Radeon HD 4600 Series (OpenGL ver:3.3.11672 Compatibility Profile Context)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 3.3
Shading Language: 3.30
Driver Date: 11-16-2012
Driver Version: 8.970.100.7000
Maximum Texture size: 8192 x 8192
Z-Buffer depth: 24 bits
Maximum Viewport size: 8192 x 8192
Total Video Memory: 1 GB
Hi -
Please update your GPU drivers to current versions.
@Alexander_Hesse - if a driver update helps here, can you please run SystemInfo
again and post it here so that we can see what is a good driver? To update, check the âNotificationsâ panel (Panels menu) and if there is an notification about your driver, double click on that and follow the directions from the âCheck nowâ button.
Unfortunately there is no driver update available.
âYou have the newest versionâ is the system message. I fear that the graphic unit is not up to date hardware wise and needs to be replaced.
Alex
Generally, you shouldnât trust Windows to find up-to-date GPU drivers for you, but, yes, while it looks like there might be a slightly newer 2013 driver available, it most likely wonât help you running Rhino 6 on that system.
Any further ideas, @stevebaer?
I now have reinstalled the catalyst controllcenter within the latest driver version. But the version number remains the same.
Please find the updated system info below.
Alex
Machine name: USER
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 3.3
Hi, Iâm getting this same issue in Rhino 6. I notice it particularly when Iâve been working for a period of time in a file and I try to then open another file or create a new file. I find that I have to restart Rhino in order to see the viewport. I do often leave files open for more than a day while putting the machine to sleep at nights. I havenât noticed the issue happening if I open or create new files without putting the machine to sleep inbetween, but will report back if I discover anything after more testing.
System Info:
Rhino 6 SR18 2019-9-23 (Rhino 6, 6.18.19266.14201, Git hash:master @ 3d84f88dec99b2f4e8b7497e739ed2adc2ba8ef6)
License type: Commercial, build 2019-09-23
License details: Cloud Zoo. In use by: travis ()
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: TRPC
Hybrid graphics system.
Primary display: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 8-27-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 8-27-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-27-2019
Driver Version: 26.21.14.3186
Total Video Memory: 11 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp âCommandsâ 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\Export_FBX.rhp âExport_FBXâ
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp âWebBrowserâ
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp âRhinoScriptâ
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp âAnimationToolsâ
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp âIdleProcessorâ
C:\Users\travi\Documents\HDR Light Studio\Rhino 6\HDRLightStudioTexture.rhp âHDRLightStudioTextureâ
C:\Program Files\Rhino 6\Plug-ins\export_OBJ.rhp âexport_OBJâ 6.18.19266.14201
C:\Users\travi\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\CreateQuadMesh (5bf6c0f3-3657-4ad5-834a-bbbb52706a40)\6.0.6950.16446\CreateQuadMesh.rhp âCreateQuadMeshâ 6.0.6950.16446
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp âRhino Renderâ
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp âAlerterâ
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 6.18.19266.14201
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Users\travi\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\OctaneRenderForRhino (f109bd23-4cf3-4c0b-9f83-06be474b0152)\2019.1.1.114\RHI Installer 6\Rhino 6.0\x64\OctaneRenderForRhino.rhp âOctaneRenderForRhinoâ 2019.1.1.114
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 6\Plug-ins\import_SVG.rhp âImport_SVGâ 6.18.19266.14201
C:\Users\travi\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\rhino-render-next\0.0.2\RhinoRenderNext.rhp âRhino Render Nextâ 0.0.2.0
Does it still happen if you have Octane disabled?
Hey Nathan,
Fortunately or unfortunately, I havenât been able to reproduce it since my last post with Octane enabled and or disabled. Iâll reply back if I can find a repeatable case where it doesnât fully load the views.
Lets keep it on fortunately. Enjoy working with Rhino and Octane and non-black viewports
Thank you for this hint. This seems to work as long you donât switch to rendered view. Iâll keep on trying after staying away from using Rhino 6 for a while now.
Hi Alexander - please run the Rhino SystemInfo
Hi Alexander, I have had an older version of Rhino so downloaded the trial version of the 6. I am experiencing the same problem as you did a few months ago. Black viewports, pan, pivot, etc. commands only work in wireframe mode because that is the only one that has âWindowsâ option in the properties. I tried to reinstall my graphics card, nothing. Did you find a solution to this issue?
Hi - please run the Rhino SystemInfo
Iâm experiencing similar issues with my Rhino and it having a black screen when opening. I updated my drivers and restarted everything so Iâm unsure what to do next. Any help is appreciated.
Rhino 6 SR31 2020-11-10 (Rhino 6, 6.31.20315.17001, Git hash:master @ ff08c426b1ef7d3a1c50a01e5e87220a68a9f815)
License type: Educational, build 2020-11-10
License details: Cloud Zoo. In use by: Caitlyn Wolford ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-I6B6V58
Non-hybrid graphics.
Primary display and OpenGL: IntelÂŽ UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 8-27-2018 (M-D-Y). OpenGL Ver: 4.5.0 - Build 24.20.100.6291
Secondary graphics devices.
NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 11-6-2020 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Intel
Render version: 4.5
Shading Language: 4.50 - Build 24.20.100.6291
Driver Date: 8-27-2018
Driver Version: 24.20.100.6291
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp âCommandsâ 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 6.31.20315.17001
C:\Users\Caitlyn\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll âEnscape.Rhino6.Pluginâ 0.0.20237.1315
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 6.31.20315.17001
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp âV-Ray for Rhinoâ
Hi Caitlyn -
As you see from this information, you have configured your system so that Windows is using the wimpy Intel 630 as your main display device. Your nice NVIDIA is not being used.
It is possible / likely that all you need to do is to put the cable from your monitor in a port on the NVIDIA card.
HTH,
