Rhino 5 ungroup All child group object when create by command ArrayCrv with Record history = Yes
Pls help. I am Support for Jewelry Designer Dept.
Thank you.
Mongkolchai
Bangkok Thailand.
Thank you.
Mongkolchai
Bangkok Thailand.
Hi
If I understand the question correctly, the command you are looking for is Historypurge - this will delete history data for the selected objects.
If it’s a question of the objects being looked, you need to right-click RecordHistory in the Status Bar and de-select Lock Children.
HTH, Jakob
Hi Thanks for you reply not object lock, ArrayCrv copy Group Objec1 to Object1_copy1, Object1_copy2, … all copy to Ungoup.
step to test command in rhino 5
step 0. Create 1.Cicle, 2.Rectangle, 3.Cicle big size
step 1.Group 1.Circle with 2.Rectangle
step 2.Click Object on step 1 and run command ArrayCrv
step 3.and Click Object 3.Cicle for path curve Basepoint
step 4. enter items number 5
all 5 items copy object to ungroup Circle from Rectangle
my user work with rhino 4 to not ungroup and keep history.
