I have a problem by removing objects from groups in C++.
I followed a sample that I found on GitHub, this works fine, but if the user wants to undo the changes, the objects will not be restored in the original groups.
There is a solution for this or eventually a different way to do it?
It’s a customer request. I have made a plugin for scaling the curves with specific parameter. There is a case that the user can set a group as input for my algorithm. In this case, the customer wants that this set of curves will be un-grouped at the of the calculation.
