Rhino 5 step export all the objects as a unique block named "document"
Hello, someone knows why Rhino 5 exports in .step all objects in one block named “document”
The block named “document” doesn’t exists in the original Rhino file but when I export or save the file in .step or .stp I found that all the object are stuck in a block named “document”. I didn’t find an option not to have this block in the step file. I wish not having blocks in the step file as in the original Rhino file.
Thank you.
It’s an old issue which exists on Rhino 5,6,7. Hopefully it will be fixed in Rhino 8:
https://mcneel.myjetbrains.com/youtrack/issue/RH-63431
Thank you.
