First I would like to introduce myself. I am a 23 year old building engineer from the Netherlands. At this moment I am working on a DIY camp trailer.
I have designed this with my own building CAD-software and created a DXF file from it. For the CNC milling I have to create a .STP file and I am trying to do this with Rhino 3D .
The shape has to be extruded to 15mm, because the base will be made from 15mm plywood. At first I imported the DXF file in Rhino and then I used the tool ‘extrude’. This is the moment when it fails, because the smooth edges turn into angular sides and I have no idea how this could happen. The same thing happened when a friend of mine imported it in SolidWorks. Does anybody know how this could happen? And maybe someone is willing to fix this for me? I have attached the two regarding files.
Here are the files in both RH4 and STEP formats. Units were changed to mm and the geometry NOT scaled. The height of the camper is now about 1.5 meters whereas it was 15 meters.
Hi Wim, thanks a lot for your cooperation. Since I have a lot of error messages, could you please do one last thing for me?
Change the extrusion from 1.5mm to 15mm? And then export as a STP file. I would be a very lucky man with that! hehe
Opening, extruding and exporting the file was no problem, but I was not able to open it in a STP viewer, it said there was a problem that could not be fixed. I probably do not have enough knowledge of this software, because I am used to building CAD software.
