Rhino 07 out of memory when rendering
Hi. When I try to render on Rhino, it says “out of memory”.
It is not my RAM. I tried with 16 GB and 32 GB it did not change.
Please someone help me!! I need to deliver a design.
What’s the polygon count? What are you rendering with? We have no way of helping you given no information. Either you ARE simply running out of memory–what are your virtual memory settings, you can’t have none no matter how much RAM you have–or there is something wrong with the model causing the polygon count to go to infinity.
Also do post the result of the Rhino command _SystemInfo
