RHI install error
Hi guys
i have a problem with plugin installation.
When i install .rhi plugin file, the installation proceed correctly but when i open rhino appear a message that tell me “error loading plugin”.
in the plugin list i don’t see the plugin that i’ve installed, but there is in C:\user\appdata…plugin folder
thankyou so much
Which plugin is it?
speckle
i already write on speckle forum but i search other general info
I observe the identical problem with a self written plugin.
Executing the plugin_X.rhi seems to work fine. I also see the installed plugin in folder
C:\Users\xx\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\plugin_X (<GUID>)\<version>\Rhino7\plugin_X.rhp.
But when I start Rhino7 afterwards during completion of the plugin installation I get the “error loading plugin” message mentioned above.
To enable using of the plugin I afterwards can install via the pluginManager using the rhp file from the previously created folder (see above), but I would prefer to fix the installation via the rhi file.
Hi @RoLippold,
Where can we find this .RHI?
– Dale
Hi Dale,
thank you for your reply.
This plugin is not a public one, you will find it here aqRay_Release1.3b.rhi
It is compiled for Win10 x64 and requires
  • Microsoft Edge and
  • Microsoft Edge Webview2-Runtime
to show its GUI. But I think for only installing the plugin (to reproduce the “error loading plugin” message ) these components need not be installed.
Kind regards
Roland
Hi @RoLippold,
Your plug-in installed for me without any issue.
Not sure where that leaves us.
– Dale
Hi Dale,
thanks for your test. I am also not able to reproduce the problem on my machine, but I observed it on machine of a colleague. So I will track it further.
Roland
Hi Dale,
unfortunately I could not find out meanwhile what’s the reason for the
“error loading plugin” message when executing my suspicious rhi on certain machines. Could you give me a hint, which circumstances could lead to such error behaviour?
Thanks in advance
Roland
Hi @RoLippold,
Sorry, I don’t have any hints.
Perhaps it’s time to move over to the Package Manager?
Note, the Rhino Installer Engine is obsolete.
– Dale
Hi Dale,
thanks for your recommendation of the Rhino Package Manager Yak. I use it now and the distribution of my plugins became more convenient for the users.
Now I would like to create the *.yak file within the CI process in azure. Is there a possibility to access the yak.exe within azure pipelines?
Kind regards, Roland
Hi Roland, take a look at this!
Hi Will,
Downloading yak.exe via curl is all what I need for my CI job.
Thank you, Roland
