Hi all, I’m trying to connect an ollama model through openAI compatible script.
The OpenAI script works well in VS code but failed to work in Rh8 Python component.
Full output is:
{0}
- Rhino.Runtime.Code.Execution.ExecuteException: Environment “default” is corrupted due to a possible package installation failure
—> Rhino.Runtime.Code.Environments.CorruptEnvironException: Environment “default” is corrupted due to a possible package installation failure
at Rhino.Runtime.Code.Languages.PythonNet.CPythonEnviron.ThrowIfCorrupt()
at Rhino.Runtime.Code.Languages.PythonNet.CPythonCode.Execute(RunContext context)
at Rhino.Runtime.Code.Code.ExecTry(RunContext context, IPlatformDocument& doc, Object& docState)
at Rhino.Runtime.Code.Code.Run(RunContext context)
— End of inner exception stack trace —
It works when I used an older script in Rhino 7 and copy to Rhino 8.
The script is referenced from a post from last year.
And it works well using Rh7 Python component, and copy-and-paste the compone to Rhino8 as well. (Screenshot below is the Rh7 component copied to Rh8)
I am happy to use the worked one in Rhino 8, but for long-term, it would be great if I could use it properly with new Python component in Rhion 8 with OpenAI compatible scripts.
My last attempt is to copy the old script into new (Rh8) python component, it shows urllib2 not found. But I failed to pip install urllib2 as well.
May I know how could I achieve both “connect the local ollama model” & “use Rh8 Python component” at the same time?
Thanks in advance!
(I am using the latest rhino (8.9.24194.18121, 2024-07-12), Educational license)
