Rh6 stuck compare to RH4, why?
Hello ,
On my laptop ( Win7; Intel i5, 4Gb ram , Packard bel EasynoteTM)
Rh6 is very slow compare to RH4.
It get better when I zoom far in , and when there are less object in the viewport.
I’am running Rh6: 6.2.18065.11031, 06/03/2018 evaluation mode.
Please find attach:
1/ A link for a video showing the problem: https://vimeo.com/260253523
2/ A file to describ my config;DxDiag.txt (25.5 KB)
3/ and a test file (( inside zip)) around 7Mb but I start feeling a difference for file around 4mB.
test_rhino.zip (1.3 MB)
4/ Rhino _systeminfo command result:
systemInfo_command.txt (1.4 KB)
Do I miss something ?
Any help are welcome
Thanks
Have nice days
I think your Intel HD Graohics card is not supported. The recommended OpenGL version for Rhino 6 is 4.1, your card is supporting 2.1.
Hi @fredcab66,
Your system also has an older Intel I5 processor and only 4GB of RAM. Pretty under-powered by today’s standards.
Here are the system requirements for Rhino 6 for Windows.
https://www.rhino3d.com/6/system_requirements
– Dale
Perhaps after this line:
OpenGL 4.1 capable video card is recommended.
You could add the following:
Systems with video cards that cannot run OpenGL XX or higher are not supported.
–Mitch
Hello Everyone.
Thanks for your fast input, yes clearly my laptop is too old.
I read the “recomended” criteria but I was thinking that 's recomended for doing advanced CAD, as I 'am just doing few polyline. and it was already fine in RH4, It could have been ok.
On the other side: the french translation of :
“No more than 63 CPU Cores.” should be " Pas PLUS de 63 coeurs" missing PLUS.
Thanks everyone.
Fred
