I keep having a weird problem since starting to use RH 6 + GH .
no matter what file size I am using , each of the viewports will freeze and turning to black when i leave the file open for a certain time ( say 2 minutes or so ) without any action.
after this time the shown view freeze and when i try to move/rotate it the viewport turns to black.
SOLUTION : the only one solution i have at the time to “unlock” the viewport is to change display mode on each of the viewport , 1 at the time , only after doing this the given viewport display will start to work again.
despite I am still able to work this is annoying behavior , any suggestion ?
I’d say that this is happening with each display mode…each view will
freeeze after a few minutes with no actions on the mouse
all i need to do is just to switch the display mode of each view to a
different one ( I’d say no matter which ) and everything start to be
correctly displayed once again
Could you try to unload all plug-ins and make sure they don’t load on startup. Then see if the issue happens. If not, then it would be possible to figure out which plug-in is causing the problem.
