RH subd, how to panelize the resulting surface
Now that RH subd allows us to creat freeform surfaces, what is the optimal workflow to panalize these surfaces?
1/ transform them to nurbs surfaces and tackle in GH? lunchbox…
2/ explode the subd surfaces into individual surfaces where each one is considered as a panel?
What is your alternative workflow?
Seems like I’ve touched a fabrication secret topic…
you know what, you can pm me if you want to keep it safe :wink:
Come on, we would like to hear your best workflow architects!
So the correct workflow I think will be converting the subd surfaces into nurbs and you can do panelization as usual.
To extract a flat base shape from a SubD object, you can use the “ExtractControlPolygon” command in Rhino.
