RGB Colours not coming out as expected
Hi There,
I was trying to make myself a simple tool to display an integer using resistor colours, but some of the colours I was choosing display completely wrongly.
In the example here, I used the Colour Picker to choose (143, 72, 19), which is a fairly rich brown colour, shown correctly in the two little squares in the bottom-left of the picker, but when I then use the Custom Preview to apply this to a plane surface, the colour comes out as a much lighter orange colour.
Some of the other colours I was using are fine, but Orange (247,164,47) comes out as very similar to Yellow (255,255,0).
What am I doing wrong? Is this a Windows issue?
See component at the end of:
ResistorColoursTest.gh (19.8 KB)
Bob
check if in Rhino you are in wireframe or shaded view
wireframe:
shaded:
close enough I guess :slight_smile:
Sigh! I had not appreciated that wireframe view would change the colours. Thanks so much - shaded or rendered view seems to fix the problems!
Yes, I should go back and re-sample the colours from some recognised pallet for resistor colours. Your orange is better than mine.
Thank you again,
Bob
Fixed the colours to agree with Wikipedia, and converted to cluster:
ResistorColours2.gh (19.1 KB)
Now, back to the real project!
Thanks again,
Bob
Conversion from Color to Material is incomplete.
If you need a constant “flat” color, do something like this:
Aha! More Black Magic!
I find these automatic type conversions that appear to ‘just work’, but may actually do something unexpected, to be so confusing! Colour → Material worked for some colours and failed for others, but only in wire-frame mode!
But yes, fixing Diffuse and Specular to Black and using only Emission for the colour give the right answer in all display modes.
Many thanks!
Bob
