A while back you were kind enough to send me a script that changed the default display of a selected component’s wires from green/grey gradient to solid green. Could you resend that? Also, a coworker was asking if there is a way to change the color of non-selected wires for color-coding purposes. Interesting idea…
Thanks for this. I had a play with this and now I’m stuck with funky coloured Grasshopper wires (and components as I had a play with this as well). How do I get it back to normal?
Is there a way to reset to default display? (yes I’ve tried turning it off and on again)
In the Grasshopper menu, go to File→Special Folders→Settings Folder. Then close down all instances of Rhino and delete the grasshopper_gui.xml file. This will revert all UI colours back to default settings.
