Hi forum, does Revolve respect the Cplane or does it work independent from the Cplane?
Example I tried today: used 2 circles , both tilted at 3 degrees in right view. The circles were let’s say 1” apart( one above the other) and a profile curve connected to the two circles. Picked revolve,then the profile curve, then the center point of each circle. Of course it didn’t work. I used 2 rail sweep after that. Did I need an axis line to make it work with revolve? I will experiment tomorrow. Thanks,Mark
The Revolve command prompts you for the ends of the axis.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/revolve.htm
