Using ‘Project Location’ you can extract the Shared Coordinates System as a plane and using the Grasshopper ‘Orient’ component you can transform the geometry.
Seems similar to this other topic.
We have added this context menu option to set the current Rhino viewport CPlane at the same place and oriented like the selected Revit element Coordinate System.
In the screenshot the ‘Survey Point’. You can also do the same with the Shared Site witch is the origin of the Shared Coordinates System.
Also works with other elements like a Linked Model, Revit Levels or Revit Reference Planes.
