hi, I’m having an intriguing problem, which I am wondering if anyone can weigh in on. Certain breps in Rhino are being translated into triangulated geometry when brought over into Revit using “Sample 2” from the Github repo.
After examining all of the geometry closely, I think it may have to do with the edge or vertex tolerances. For example, this comes over fine:
polysurface
Object name: (not named)
Layer name: Box Metal
Render Material:
source = from layer
index = -1
Geometry:
Valid polysurface.
Closed solid polysurface with 6 surfaces.
Edge Tally:
12 manifold edges
Edge Tolerances: all 0
Vertex Tolerances: all 0
Render mesh: 6 fast meshes 24 vertices 8 polygons
Analysis mesh: none present
But this ends up triangulated:
polysurface
Layer name: Box 1
Render Material:
source = from obj
index = 690
Geometry:
Invalid polysurface.
Edge Tally:
12 manifold edges
Edge Tolerances: 0 to 0.0010581
median = 8.72066e-05 average = 0.00030539
Vertex Tolerances: 3.35858e-05 to 0.00105916
median = 8.72938e-05 average = 0.000316833
Geometry UserData:
UserData ID: 3B7FB506-437C-431e-B1D7-93C4CBFF417F
Plug-in: Rhino
description: Gumball grip frame
saved in file: yes
copy count: 20
For visual reference, “A” is what a triangulated brep looks like. “B” is what that same Brep looks like if it is exploded and brought into Revit as individual surfaces (I moved the surfaces apart a little to illustrate). Running join on the surfaces after exploding them results in “A” again. If I extrude one of the exploded surfaces, I get “C” which is the desired (clean) result.
For now, I’m working on an additional component to contribute to the RIR github, which will check the tolerances of breps, to help identify ones which may need reconstruction…
Also, I think I may have found the code responsible for creating the triangulated version, it seems be there as a fallback for if the preferred method fails. In Convert.cs at line 438:
else
// Emergency result as a mesh
var mp = MeshingParameters.Default;
mp.MinimumEdgeLength = Revit.VertexTolerance;
mp.ClosedObjectPostProcess = true;
mp.JaggedSeams = false;var brepMesh = new Rhino.Geometry.Mesh();
brepMesh.Append(Rhino.Geometry.Mesh.CreateFromBrep(brep, mp));foreach(var g in brepMesh.ToHost())
yield return g;
