I have been tweaking the number of points per foot of contour to add to the host. But even if I push it higher, revit is still drawing contours with weird jogs:
Just wanted to mention that the current geometries I am using are on this post. These are the contour lines that were traced from a survey map, rather than extracted from the surface patch. I am still running into the issue with contours cutting off.
