Revit cannot run the external command "Grasshopper"
After updating Rhino.Inside to version:
RhinoInside.Revit_0.7.7815.25113
I keep getting this error when I am trying to start Grasshopper from Revit 2020.2 (no error is being thrown in Revit 2021.1.2)
See this post please and let me know if you have any of these apps installed
Thanks for getting back to me Ehsan, it was ComputeHub addon that was conflicting with RhinoInside.Revit
Glad you found the conflict. What does ComputeHub do?
Hi @tatjana.somova,
There is a new release (v0.8) at ‘Daily Channel’ that hope to fix this problem.
May you confirm us it is fixed on your side?
Thanks.
How did you solve the problem please ?
Hi Kamal,
Please see out troubleshooting and known issues guide.
Hi Japhy, thanks for the link - I don’t see this issue under the known issues or troubleshooting guide. Is there a solution for this? I am getting the same problem in Revit 2019.2 with the latest Rhino.Inside
Hi Maxime,
Can you provide your About info?
These are typically Revit Addin conflicts, but there was a similar unresolved report yesterday.
I’m not seeing an issue currently.
Rhino.Inside Revit: 1.18.8670.30281 (2023-09-27T16:49:22)
Rhino: 7.34.23267.11001 (Rhino 7)
Revit: 2019.2 (20210416_1515(x64))
CLR: 4.0.30319.42000 (4.8.9181.0)
OS: Microsoft Windows NT 10.0.19045.0
Hi Japhy
I’ve saved a message log of how I encounter this error, screenshot below:
I didn’t send any error report though because it does not give me the option to do so
RhinoAssemblyResolveLog.txt (554 Bytes)
Thanks,
Maxime
I am also getting this error on Revit 2019.2
I’ve disabled all plugins, Rhino Inside will start but Grasshopper will not.
RhinoAssemblyResolveLog.txt (1.1 KB)
Try opening Rhino and initiating GrasshopperLoadOneByOne in the Rhino command line.
I’ll have access to R2019 tomorrow and will test on my end.
Most plugins loaded one by one without any problem, but I got this error:
Priority: GhpyLoader
The Rhino IronPython plug-in could not be loaded. It was either disabled, or it cannot load on your system.
ApplicationException
After dismissing it, GH opened!
