RevisionClouds in RhinoCommon
Hi there,
when investigating if I could automate revisionclouds I did not find anything in the documentation.
Then I start converting/dividing a polyline/polycurve into segments and try to make the “cloudy” arcs out of the segments based on their orientation to the center of the curve.
I just wonder: Is there some easier way to do this, e.g. an existing method?
Of course I could do this via a commandline script as well, by selecting the curves and running the _RevCloud command then.
Thanks,
T.
Hi @tobias.stoltmann,
There isn’t a method, in RhinoCommon, for creating a revision cloud from a closed planar curve. I’ve added this to the heap.
https://mcneel.myjetbrains.com/youtrack/issue/RH-84353
– Dale
RH-84353 is fixed in Rhino 8 Service Release 14
