I am using that option.
But if you have a lot of revision clouds on a layout ideally the cloud arcs should have the same size.
This is not possible with ‘divide’ since the command only divedes the length of the curve with the number of arcs. You can eyeball it, but it’s time consuming.
Would be great to have it as annotation scaling so the layouts always look crisp and nice
The “Length” option specified allows you to set the arc length for each arc segment. Therefore the arcs should be more or less the same size for any length rev cloud curve (except for the last arc needed to close the curve). What would be good @pascal would be to have an option to have all the arcs the same size including the last one - that is to say that the divide/length would make all even divisions closest to (but not exactly) the length input…
