I need some help splitting and manipulating a data tree of point lists. I have a data tree with many lists of points. The lists are split up by Z height, (this is going to be used for 3D printing layers)
I am now trying to reverse the points in every other list. Is there a way to reverse only the odd lists in a data tree?
Many Thanks
-B Carver
diff-arch
(diff-arch)
June 26, 2022, 7:31pm
#2
Sure, you can for instance do this:
You can use Dispatch instead of two Cull components.
Awesome! thanks ill give that a try. Im still pretty new to grasshopper and data manipulation
Will dispatch apply to separating the lists or only the individual data points?
My proposal is the same as diff-arch but instead of two culls - use dispatch.
Tree statistics β dispatch the paths with a true-false pattern β 2x branch β reverse one of the branch components β merge
Gotcha, I just got it as I worked through diff-archβs solution. Thanks so much!
